1.On mobile iOS devices (iPhone, iPad)
2.Sync chain with desktop Mac
3.Unable to find extensions and bookmark shortcut on mobile devices
Find the above Brave Version( check About Brave):
1.21 Mobile Device details
iPhone 7 (iOS 14.2), iPad 6 (iOS 12.4.6) Additional Information:
@robgo2,
iOS at this time only syncs bookmarks data, so any extensions installed on your desktop installation will not be carried over.
That said, you should still be seeing your bookmarks synced. After adding both devices to the same Sync chain, have you closed/relaunched the application on both devices?
@robgo2,
Excellent β just making sure your bookmarks got there. Yes, not all Sync features are available for iOS at this time. Appreciate your patience and glad you were able to get bookmark sync running.
