Introducing Brave Rewards Beta for Android & a call for testers!
Please read through our Help Center articles before opening a topic.
Rewards Help Center
Please fill out the template below:
Briefly describe your issue:
What Operating System and Brave version are you using? (Menu --> About Brave)
Who is your verified custodian? (Uphold/Gemini/bitFlyer)
where is the download link of the version 1.0.88 browser i try to download on playstore but its not 1.0.88
yeah, there is no 1.0.88
playstore is 1.0.84 not 1.0.88
wait, i download it from github
Is there a way to backup the BAT wallet on mobile devices?
Is it possible to use the same wallet for android and brave or it hasn’t been implemented yet?
Is it possible for a user use the same wallet on android and the PC?
same question
there isn’t any way to backup the BAT wallet on android device’s version.
If this is true, it should be implemented asap.
