I love using Brave on the desktop, tablet, phone, BUT I’ve spent many hours realizing that Brave has a problem that is not exhibited in Firefox or Microsoft Edge. If you open the NeierInc.com website & then use Inspect & then select Network & the Block Requests Filter, you will see 3 errors shown on the Home page. You will see only the Google Analytics error shown on the other pages. The Home page shows 2 errors associated with Google Maps, which are also used on some other pages.
Until you can come up with a fix for this problem, I will be forced to use Microsoft Edge for these types of tests. Firefox isn’t that good of a solution since it doesn’t allow the above filtering, as far as I can see.
NeierInc.com
I have Shields turned off while doing website development.
See previous answer.
I don’t use Chrome.
Version 1.32.113 Chromium: 96.0.4664.45 (Official Build) (64-bit)
