If I copy a bookmark to another folder, other bookmarks with the same target, but in unrelated folders, are deleted.
This post is written in the context of this behaviour occurring when copying bookmarks from mobile device to desktop, as that was my use case. However, it also occurs in the context of desktop alone.
Steps to Reproduce
in Bookmark manager on desktop…
- create folders TEST-desktop and TEST-android
- bookmark site-A in TEST-desktop folder
- bookmark site-A on synced device (bookmark appears in Mobile bookmarks folder on desktop)
- drag bookmark from Mobile bookmarks to TEST-android folder.
- TEST-desktop folder is empty
Actual Result:
GIF shows bookmark dragged from Mobile bookmarks folder to TEST-android folder, then bookmark now missing from TEST-desktop folder.
I don’t expect bookmarks to disappear from other folders when moved about in unrelated folders. I expect bookmarks to be remain duplicated except where explicitly moved. The current behaviour is a bug.
Reliably.
Actually (I’ve just tested) and this behaviour also occurs when copying a bookmark from one desktop folder to another. This would be expected normally, but it also occurs when (copy) key is down and ‘+’ decorator is visible on the mouse pointer.
UPDATE: This behaviour is also enforced explicitly by the ‘bookmark’ operation in a normal browser window. The dialog enforces selection of a folder, and this selection deletes bookmarks with the same target in other folders.
ALSO: This behaviour can be circumvented by copying and pasting bookmarks rather than moving (including from mobile bookmarks folder). This is inconsistent but also a potential workaround for my particular use case.
Operating System and Brave Version:
desktop system:
Linux lyra 6.1.0-22-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.94-1 (2024-06-21) x86_64 GNU/Linux
Brave version:
Version 1.78.102 Chromium: 136.0.7103.113 (Official Build) (64-bit)
I’ve reported this in the context of syncing with a mobile device, but now I see the same behaviour in the context of desktop alone. I won’t recreate this post for that instance, but the sync/mobile context is somewhat redundant. Focus on the semantics of bookmark management,
