Bah, I canât sleep and got a notification on this topic for some reason. Let me hit on some things. Before anything, sucks to hear you got hit and dealing with it. And yeah, because Iâm tired, will be a bit more direct which may seem rude. I can try to revisit later to clear things up and try to rephrase nicely if need be.
That saidâŚ
- This would have happened regardless of the browser you use.
- Itâs often due to Discord or games where people add this malware to their own devices
You realize malware is like someone breaking into your home, right? You would be correct that it ideally shouldnât happen. But regardless what security methods you use, itâs going to happen. This is especially true when you donât properly keep things secured.
You did. You said the browser should act independent from the system. Hikane was explaining to you that thereâs no way for it to act independently. The browser itself and all the data is on your computer, which means your OS is going to have controls. It canât isolate itself like a virtual machine would be.
This is one of your major misunderstandings. You keep wanting to attack and argue as if you can have the browser completely independent and untouchable.
Who said itâs plain text? Everything is encrypted. You just seem to be unaware of the different types of encryptions and seem to have no comprehension about why things are or arenât possible.
You may want to check out sensitive data storage where they touch on this a bit. You can also see a Google/Chromium article here
When youâre logged in on your computer, things are unencrypted. It needs to be so you can use it. Otherwise if it just kept full encryption then you wouldnât be able to do anything. All websites would be blocked.
Itâs kind of like an alarm system. When you leave the house, it becomes enabled. If anyone enters it will be locked or sound an alarm when someone tries to force an entry. But when youâre home, it isnât set. Otherwise every time you move it would set off the alarms and be a constant headache.
It is possible to get access to the encrypted file where your seed phrase and private key is stored. They can then move this file elsewhere and brute force password guessing software can be used to get your password.
This is one of the potential dangers of a software wallet and why many recommend hardware wallets, especially if youâll be using crypto much.
Brave and all the browser companies are always looking into things. OS are always making updates as well. Nothing is perfect and there will always be new bypasses when security is tightened. This isnât an ideal world where all threats can be neutralized. All that can be done is for everyone to make best effort.
Welcome to the real world. Nothing is perfect. All locks can be picked or bypassed. Computers can be hacked. Data can be stolen. Banks get robbed, houses catch fire, and many other crazy things in life.
Honestly, this whole issue likely is a result of something you carelessly added to your own device. Porn, video games, torrents, crypto faucets or airdrops, or whatever else. At least that tends to be the scenario for this malware.
