Briefly describe your issue:
I ve updated my desktop to Windows 11 and now have reached the max limit of devices. Please help me I already use a mobile device and I have verified wallet in it, and before my win update everything was working fine
What Operating System and Brave version are you using ( Menu --> About Brave )?
Win 11 & Brave Version 1.30.89 Chromium: 94.0.4606.81 (Official Build) (64-bit)
no
On my last pc it was two months ago or something
yes
Are you using a VPN? (yes/no)
no
Are you in a supported region for list of supported regions)?
yes
Does your device pass the check (Android only)?
Yes. i am using my android brave app without any problem
yes
Greeting!
