I havent been able to get the brave adds on my device ive tried everthing in the help forum but mothing is working
Please ensure that you’ve read through the following topics/pages thoroughly before opening a topic as your question may have already been answered:
Briefly describe your issue:
What Operating System and Brave version are you using (`)? windows Version 1.28.106 Chromium: 92.0.4515.159 (Official Build) (64-bit)
Is your browser wallet currently verified? (no)
Are you using a VPN? (no)
Are you in a supported region ( for list of supported regions)? yes
**Does your device pass the [SafteyNet](https://play.google.com/store/apps/details? yes
** yes
