I have this problem
brave_dknD8P3hbA
@hitech We’re going to need a lot more information from you in order to help. Please provide the following
What OS are you using?
What version of Brave?
Is that happening in any other app/program or only Brave?
How can the issue be reproduced?
If just downloaded, where did you get it from?
I assume by “this problem” you are referring to the visual artifacts on the screen (as shown in the animated GIF). If so, please try disabling Hardware Acceleration to see if that resolves the issue for you. This can be done at runtime with the --disable-gpu flag, or via brave://settings/system.
If disabling Hardware Acceleration resolves the issue, the problem is likely with the graphics driver you have installed, and an incapability with the version of Brave being used. Try updating your graphics driver to see if that addresses the behavior.
