I have not received payments for more than 2 months
Briefly describe your issue: I haven’t received payments to my Uphold account in over 2 months.
What Operating System and Brave version are you using (Menu --> About Brave)? Versión 1.61.101 Chromium: 120.0.6099.71 (Build oficial) (64 bits). Windows 10.
Is your Brave Rewards Profile currently verified? (yes/no) yes
What date did you connect a your Brave Rewards Profile? I don’t remember, a long time ago
Have you been able to successfully receive payments in the past? yes
Are you in a supported region (see here for list of supported regions)? yes, Argentina
Does your device pass the SafteyNet check (Android only)? -
Have you fully completed Uphold’s CDD requirements? yes
@xlukii you will need to create a Rewards Support Ticket at https://support.brave.com/hc/en-us/requests/new?ticket_form_id=360001302431 so someone from Brave can have the necessary information to look into this for you.
Hi. I haven’t received Brave Revard in over 6 months. Right now my operating system is macOS 14.2, and it also doesn’t work on iOS 17.2. I update the Brave browser systematically.
My profile is a few years old and up until a certain point I was getting the reward every month. USA. Uphold’s CDD - yes.
bruh they flagged you for no reason like everybody else asking the same thing everyday, send a support ticket and maybe you’ll be the one getting unflagged
