Briefly describe your issue:
Hi, as the title says I have been using Brave browser since ~June of 2021 and only received 2 BAT since than as rewards. I’m not sure if it’s normal or not but I expected a bit higher rewards to be honest
. My ads are set to maximum possible in the settings, besides that I’m not sure what could be the issue. Do you have any info about this?
e is up to date
Version 1.43.89 Chromium: 105.0.5195.102 (Official Build) (64-bit)
Windows 10
Not entirely sure but it’s not connected to Uphold or Gemini
Not exactly sure
Yes, but very little amounts
Are you using a VPN? (yes/no)
No
Are you eligible for Brave Rewards (see here for list of supported regions)?
Yes
Are you on the list of supported regions when verifying Brave Rewards with a custodial partner (see here for list of supported regions)?
Yes
Have you manually turned off Auto-contribute on all of your devices linked to a custodial partner?
No
