Hello to all. Since last year, 2020, approximately since October, I have the same amount of BAT and I have never received the corresponding payment. I look forward to your help, thank you very much!
Hi, @Frodo, the Creators’ payout is processing now. Please read through Support’s thread carefully, and for watch any updates.
Hello, thank you very much for your reply. Are all the creators in the same situation as me and have not received their payments since last year, or did I do something wrong?
Hi, @Frodo, I really don’t know, I’m sorry. I think there may be technical issues, and issues with porting to Uphold; I also think some have tripped anti-fraud detection - either accidentally, unknowingly, or knowingly.
It’s only my humble opinion, but if a Creator or non- haven’t received BAT payouts for some months, they should consider that Brave may have seen indications of suspicious activity according to their detection system. Getting in touch with Support is best, providing all the details asked for, and being forthcoming and honest.
Anyone more knowledgeable than me on this topic is welcome to correct me if I’m mistaken.
Same I’m also struggling with that same problem
Hi, do you know what email address I can send a message to in order to contact support? The problem persists.
Hi, @Frodo, have you sent the information in a DM to steeven?
However, it looks like you’re affected by a known issue with BAT not porting to Uphold. You can keep an eye for any updates here:
You could try the fix, too, it has worked for some.
Make sure you have the latest browser version, then disconnect and reconnect from Uphold. If it works, the BAT will drain into your account.
Yes, I have the same problem. Have had over 21 BAT sitting in my Brave Publishers account for several months that never gets paid, even though I have my Gemini Wallet connected and have received payments before. Every month I wait, and the payment never processes.
A new update got released. Make sure you have the latest.
