i didnt see any ads for a while i think my accout get flagged by system can you fix this?
@Ercah It can be common not to see ads for a while. It’s all based on how many ads are available in your region, how many of those ads are meant for your OS, wh8at your notification settings are like, etc.
I’d also like to point out there was a template requesting information from you in order to try to provide assistance. It seems you deleted that. If you could, we need that info. So I’ll share the template below once more, do please try to answer everything:
Briefly describe your issue:
What Operating System and Brave version are you using (
Menu --> About Brave)?Is your Brave Rewards Profile currently verified? (yes/no)
Are you using a VPN? (yes/no)
i got many payments in the past i dot using vpn ad im living in turkey my brave profile almost 2 years old. and its verified
@Saoiray
