Briefly describe your issue: Around 2 BAT claimed from october’s rewards have not been yet sent to my Gemini verified wallet.
What Operating System and Brave version are you using ( Menu --> About Brave )? OS: Windows 10 Version 21H1 (Build 19043.1348), Brave: 1.32.113 Chromium: 96.0.4664.45 (Official Build) (64-bit)
Is your browser wallet currently verified? (yes/no) Yes, verified with Gemini and have received previous rewards on it.
What date did you verify your wallet? September 6th 2021
Have you been able to successfully receive payments in the past? Yes
Are you using a VPN? (yes/no) No
Are you in a supported region (see here for list of supported regions)? Yes
Does your device pass the SafteyNet check (Android only)? Not aplicable, only use Brave on my computer.
Have you manually turned off Auto-contribute on all of your devices linked to Uphold?? Yes
