I Can't claim my brave ads, when i click to claim it says something's wrong and try again later.
Please ensure that you’ve read through the following topics/pages thoroughly before opening a topic as your question may have already been answered:
Briefly describe your issue:
Are you using a VPN? (yes/no)
Are you eligible for Brave Rewards (see here for list of supported regions)?
Are you on the list of supported regions when verifying Brave Rewards with a custodial partner (see here for list of supported regions)?
Have you manually turned off Auto-contribute on all of your devices linked to a custodial partner?
Could you please fill the template.
Try until next week.
Give us a few days because there are some issues Rewards team is working on, which hopefully will push payments through for current payments. If you’re having issues with payments after next week, submit a Support Ticket
The above Was commented by @jsecretan.
Got this info here
