I cannot get my Sync Chain to work for bookmarks between iPhone and iPad
I have tried all of the tips I’ve seen from other support topics but I cannot get Brave to sync at all, especially bookmarks, between my iPhone and iPad. They are of course on the same sync chain and with all of the 4 sync options enabled on both devices.
Brave Version( check About Brave): Version 1.75 (179)
Mobile Device details iOS 18.3.1 - iPhone 16 Pro Max
iOS 18.3.1 - iPad Pro (12.9 inch) (5th Generation)
@PowerTaint just to confirm, you have checked on both devices and each show each other on the sync list? Kind of like below:
If so, then hit the settings on the top right on the sync menu, this will open Sync Internals. I want you to specifically share the information as you see in my screenshots below:
-Side Note- (unrelated to your issue)
If you’re curious, the reason why I have my desktop listed multiple times on my device list, it’s because of multiple profiles and also Release vs Nightly.
