I am having the same issue with connecting Brave Rewards to Uphold.
I have spent 3 days now trying to connect my PC running Windows 64-bit, as well as my mobile phone running Oxygen 12.
In both cases I don’t get an error. I just don’t move beyond the verify email opened by Brave browser.
I have reset the Brave Rewards on both PC & Android, as well as uninstalling & reinstalling it on both twice.
When I have uninstalled both latest versions of Uphold and Brave Browser.
Also during both uninstalls I have removed any trace of both Brave & Uphold on both PC & Android Phone.
Also through the upholds website I have set it up, as well as went through their comprehensive ID verification.
This is the procedure I follow each time I have attempted to connect Brave Rewards to Uphold & The Results.
- In Brave Rewards → clicked Connect account
- In Choose where you’d like to receive BAT → clicked Uphold
- In Scam Warning → checked I Confirm & clicked I Understand
- I enter both the Uphold Login Credentials and each new instanse of Authenticate App six digit code from Uphold
- Message on wallet browser says check email message to verify it’s me.
5b. In email I open Did you just try to sigh in? Email from Uphold and I’m redirected to my uphold wallet.
So now I’m in my Uphold wallet, but nothing mentions brave. Infact there is no mention of Brave in my uphold session.
Uphold just Shows the screens of my uphold wallet
In Brave browser still shows Verify it’s me, it never changes. The Brave Rewards still shows nothing connected.
I have been emailing back and forth to Upholds technical team, trying everything they suggested with no changes.
The Brave Rewards just won’t complete connection to uphold. So I am reaching out to your tech force to see if you can offer any additional help or solutions.
If we can connect great, if not I will just Permanently disable Brave Rewards.
It seems like a great feature, if it works. But if I can’t connect, no reason to keep it running. I will just use Brave as is.
Thank you for any assistance you can provide me.
Best Regards
Rob M Conn
robertconn@caramail.com
