I am not able to connect my brave rewards to my gemini wallet
When I am trying to connect my brave rewards to my Gemini wallet then it shows an error that region not supported please fix it because i am not able to withdraw my brave rewards to my Gemini wallet.
I have had the same issue since yesterday. I hope this is just some glitch and an update regarding this issue at the earliest would be better.
Check the latest updates regarding the supported regions
Did you try accessing your Gemini account? As far as I know that should still be possible. If so, your funds are still there to be used.
However, you will not be able to reconnect Brave with Gemini.
My advice is to keep accumulating rewards in your browser until your country is supported or until brave ads more options. They are working on it. It may take a while though.
But why did they removed “India” From their list of supported regions previously it was there but what happened that they have removed my country. If there is no support of withdrawal then why there is brave in our country.
Maybe this can help understanding
