how can i use language translator while surfing different sites in brave browser
Hey bijoy3776,
If you go to a website with a language that isn’t listed under Order languages based on your preference, Brave should ask if you want to install the Google Translate extension as long as Offer to translate pages that aren't in a language you read is on.
@bijoy3776 as Adrian already told you, you can use the google translate extension and I recommend you to set it like this
