how to unlink devices and get support trying to re verify and it says i hit max devices error please help
Yo can request manual removal.
For more information read
It may take a while bwfore you get a reply though, mine took over a month because support is probably swamped with people reaching devic limits.
I still cannoy believe they made it without an option to āreleaseā a device from using a spot that contributes to the limit. It all reminds me of the DRM of the game SPORE years.
Anyway I hope this will solve your issue soon
Same info I already posted, without the extra information.
nothing fix the problem, iām very sad with this⦠=/
Brave Rewards seems a big lie, I, honestly, hope that the support change my opinion
Yes, I think you posted it while I was typing out my reply ![]()
Did you fill out the form and have received a reply back on it? It took well over a month before I received a reply back after filling out the form.
Also when I found I found out that the issue was caused by the uphold app and suggested yo them to look into thi, I actually received the same standard response back that they unlinked ally devices. Apparently they donāt even bother reading when you reply back to themā¦
Yes, I filled out the form but i havenāt receive a reply. I got link my brave creator account on uphold, but I continue with the same problem with the browser =/
