How to save Experimental Flags settings
Currently, I am playing around with different settings to see what effects they have.
But to do this more efficiently I would like to save de Experimental Flags settings.
The problem is that I am not sure where these are saved.
What file can I copy to save the flags?
Thanks for your help in advance. :slight_smile:
@LongShortTermMemory
Create a text file named ‘Experimental Flags settings.txt’ and make well-written, detailed notes, therein. Maintain that text file; and store that text file out of the pathways of your Brave Browser installation.
That would mean I would have to reconfigure all the flags again
