- I know there is no build as 32Bit Linux version. That’s why I wanted to do it myself.
Brave 32Bit Linux
Brave Version( check About Brave
Latest Version from GIT Repository
I can download the sources from the GIT repository. There is also a manual for building. In the Debian forum I got the information that I could try to go this way for a 32bit package.
What’s wrong with trying it that way? Are there maybe specific 64Bit calls in the code, so that it can’t work? Do you know anything about this?
