I downloaded the Authenticator extension* (the icon is shown in the tool bar) but it seems it works only with Firefox, Edge + Chrome. Do you know a solution how to use it with Brave? It is then possible to enter the OTP (one time password) without a cellphone.
**Did the issue present with default Shields settings?
yes
**Does the site function as expected when Shields are turned off?
no
**Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration.
no
yes
1.57.64 / 12 September 2023
