you welcome and hope your issue get fixed soon
does not select my comment as solution or the team maybe by mistake think that the issue been solved so remove it
@Samue1 ,
This is a known issue that was just recently resolved:
opened 07:15PM - 16 Nov 22 UTC
closed 08:22PM - 09 Dec 22 UTC
bug
QA Pass-Win64
QA Pass-macOS
priority/P2
QA/Yes
release-notes/include
regression
feature/settings
OS/Desktop
QA/Test-All-Platforms
<!-- Have you searched for similar issues? Before submitting this issue, please … check the open issues and add a note before logging a new issue.
PLEASE USE THE TEMPLATE BELOW TO PROVIDE INFORMATION ABOUT THE ISSUE.
INSUFFICIENT INFO WILL GET THE ISSUE CLOSED. IT WILL ONLY BE REOPENED AFTER SUFFICIENT INFO IS PROVIDED-->
## Description
Follow up to https://github.com/brave/brave-browser/issues/26097
There are two problems when going to `brave://settings/clearBrowserData` --> `On exit`:
1. The option to save whatever data types are selected is grayed out and cannot be selected:
2. The option displays `Save` rather than `Clear data ` as it did previously. I'm not clear on whether or not this was intentional (but I do think it makes more sense this way, since you're not actually clearing data on that click).
## Steps to Reproduce
1. Visit `brave://settings/clearBrowserData` --> `[On exit]`
2. Select a data type to be cleared on exit
3. Observe `Save` button
## Reproduces how often:
Always
## Brave version (brave://version info)
v1.45.127
## Version/Channel Information:
- Can you reproduce this issue with the current release? Yes
- Can you reproduce this issue with the beta channel? Yes
- Can you reproduce this issue with the nightly channel? Yes
## Miscellaneous Information:
Internal discussion:
https://bravesoftware.slack.com/archives/C02DT9F5EP5/p1666647065097729
Community report:
https://community.brave.app/t/brave-not-deleting-history-and-no-option-to-save-on-exit-settings/441397/7
The fix is in Beta now and should be landing in Brave stable in the next browser update.
Samue1
January 21, 2023, 8:48am
24
Thanks for the reply, but the ‘save button’ seems to be of grey colour meaning I cannot complete this solution.
@Samue1 he meant that it’s an issue and they fixed it for the beta version so when you get update for version 1.48.122 or above it will be solved for your case
Yes, this is exactly correct. Thank you for clarifying @justsomeone1
@Mattches thanks for you for help
Samue1
January 23, 2023, 6:58pm
28
justsomeone1:
solved f
Thanks! I’m glad to hear that.
Samue1
February 8, 2023, 4:57pm
31
Thanks, but it says my browser is up to date, how do I fix that?
you welcome when you go to brave://settings/help what the version there?
Samue1
February 8, 2023, 7:26pm
33
The new one, I re-installed it. But now I fixed my favorite browser, so I may not be using it.
sorry but i do not understand what you mean
Samue1
February 8, 2023, 7:31pm
35
My old browser is working.
still not sure what you mean
but does opening brave and clear the cache on exit work or not?
Samue1
February 8, 2023, 8:22pm
37
Yes, it does work. Thanks!
you welcome and glad to hear that
