Auto clean history not works any more
Clearing history in exit not works.
Auto clean history (on exit) worked correct before. Now deleting history manually work correct, but auto clear history(on exit) don’t work.
Thats my options selected:
After exit from browser NOTHING changes.
Before bug detected any browser exit delete all the history. Worked nice.
All the time I closed browser.
Can’t surely tell in which moment bug was detected.
The only significant event I can remember is that I tried to sync brave on desktop(windows) and on android(which have no option to auto delete history). Idk if that have any causal relationship.
Also after I found problem I installed Click&clean extension and it clean history correct. It’s not comfortable for me to use that extension but it proves that cleaning is possible but by some reson Brave stopped to try it.
Seems the problem was that Brave continues work in background mode after closing. So exit trigger newer works. Now I turned off background mode for it and seems it works.
Suggest developers to fix this feature. As user I expect to trigger clean history when click close browser independs of factor if it continues work in background.
