How do I block a web site
I don’t give a flying hill of beans about payments. How do I block a website? Really answer, will you?
@feraltamer,
There is no built-in functionality to block a specific website in Brave. There are extensions you can get that will do this. Alternatively, you can visit the site and open the Shields panel (lion icon in the address bar) and in the advanced view, change the Scripts option to Block scripts. Since most sites use scripts, blocking them will often force the site to display or function incorrectly. It really depends on the reason you’re wanting to block the site.
@feraltamer , your energy seems liek you are ready padawan…
  1. go brave://settings/content/all
    brave://settings/content/all when you want to set permissions of that site that is nono
  2. click the URL and set block to everything if it really get on nerves
  3. ???
