How Can I Block Acsess Incognito And Tor In Brave
I want to bloack my access to incognito tab and tor tab due to some private reasons how can i do it
You can hide the “private window with Tor” at brave://settings/privacy
I am not sure if you are able to hide the incognito (private window) without Tor.
But check this out:
@rodrige is correct here for hiding the functionality, however you will still be able to use them if access via shortcut or in the Menu/Settings. To disable them completely you’ll need to use Group Policy settings (and I’m actually not sure if you can do this for Private windows), found here:
