Enable History Sync
History from PC in same sync chain should show up on iOS. Instead I see weeks only history from 3 weeks or so. Brave Version( check About Brave):
1.29 on iOS and Version 1.29.58 on Windows10 Mobile Device details
iPhone 8+ Additional Information:
Do you see no history at all? I think we only sync typed URL history not all visited links, this is what chromium sync implementation does and we followed the pattern
Ya, I had to do an upgrade via iOS app store. Right only Typed URLs are showing up now, Clicked on bookmarks on a PC do not show up on the iOS device. As I indicated on Brave’s Reddit
That should be made abundantly clear. That History is typed URLS. A normal user thinks history is aka the actual URLs that you visited either via clicking on bookmarks, links in websites, or typing in the URL.
A tip that I found in order to get a link that you clicked on via another application on a PC to show up in History sync on iOS
I have found that if I clicked on a link from another site in my Windows10 machine that link would not show up in iOS history sync.
However if on my Windows10 pc I simply backspaced over the last couple of characters in the article’s URL in Brave this will cause the article to show up in the pulldown list of suggestions. Clicking the link in the suggestion list for the same article will cause that article to show up in your History on Brave iOS.
Someone else on Brave’ Reddit pointed out that simply by adding a ? on the end of the URL and pressing enter on the keyboard will cause that url to show up in your History.
I doubt that will be possible unless Chromium implements that although I thought that Brave on iOS was based on Firefox rather than Webkit which brinks on other issues.
