Hi my key doesn't work when i use brave on another device?
Any ideas on what to do?
What “key”, @Jay9?
It’ll be better if you can follow the guidelines and provide more info about your issue.
Thanks
Hello @Jay9, you mean 2FA code? If so, it can only be active on one device.
In the rewards settings to import your key. I typed in my key but it didn’t work
@Jay9,
You’ll need to be more specific about what the exact issue is. Are there any error messages that appear after you type in your code? Are you sure the code is copied exactly?
