Briefly describe your issue:
I havent had ads for about 2 months
What Operating System and Brave version are you using (Menu --> About Brave)? Windows 11 and Version 1.34.80
Is your browser wallet currently verified? (yes/no) Yes
What date did you verify your wallet? Years ago i guess
Have you been able to successfully receive payments in the past? Yes
Are you using a VPN? (yes/no) No
Are you in a supported region (see here for list of supported regions)? Yes USA
Does your device pass the SafteyNet check (Android only)? n/a
Have you manually turned off Auto-contribute on all of your devices linked to Uphold?? No
