every time i search something appears first the thing i want and 1 sec later a lot of ads, can i somehow disable that ?
Please tell us:
Your computing device and its OS (and version)
Brave Browser version numbers
Do you enter search criteria in the URL address field? If so, what website are you visiting when you do that?
When visiting the Google Search Engine website, do you ever enter search critera in the search field (instead of the URL address field)?
Meanwhile, @Fanboynz of Brave Support, is from whom you might get a worthy response.
Do test in private window mode, with no extensions @igorvieiraz
thank you i try in private mode and works perfectly fine, so i uninstall extension by extension until was done
