Help with block elements thing
Description of the issue: i blocked some elements on the youtube website and idk how to get them back, ive seen the “brave > css (something something)” solution but that doesnt work for me because i dont have the brave option
  1. right click on site
  2. click “block elements”
  3. select an element and block it
Expected result: it should remove the element
If you click on the Brave Shields within Youtube, you should see the option to Clear Blocked Elements. Thanks!
OMG!! TYSM!!! i woulda never guessed lol, genuinely thank you :smiley:
@MystxMistakes the option they gave is how to undo everything for that website. But if you ever made multiple rules and just want to remove one, you’ll want to go into Settings → Shields → Content Filtering. From there you’ll see the Create Custom Filters box. This is each rule you made. If you had just created it, it should be listed on the bottom of anything there.
They don’t add spaces between them at times, but you’ll see where it begins based on the website URL/name. So like in the screenshot below, I did a red box of one of the last rules I made. If I needed to undo it, I would delete that and Save changes
