Description of the issue: When I updated brave this time(didn’t happen before) on my chromebook, it made it so I can’t really activate full screen and my mouse is at one place but where it clicks is somewhere else.
Have a Chromebook( My Model: CR1100CK but this has happened to other people with different models)
Paste this in VIM curl -fsS https://dl.brave.com/install.sh | sh
I guess sometimes it messes up your chromebook.
Expected result: Sometimes it makes your chromebook not be able to full screen and makes your mouse be weird
Brave Version( check About Brave): Idk it won’t work but probably latest
**Additional Information:**Model: CR1100CK
So basically, I decided to update my brave browser on linux using the code provided on their website: curl -fsS https://dl.brave.com/install.sh | sh . After doing this, when it rebooted, it now doesn’t let it go full screen and my mouse isn’t right, as if my mouse is at some place, the the place its selecting is like an inch to the left and an inch upwards. Another interesting note is that this has happened to other people I know, but it happened all the time they’ve had brave, but mine has never done that and I always assumed it was because the chromebook I’m using is a bit newer, but I guess not. (I have to literally use tab and then enter to even post this)
