Hello I call on you
I explain my problem, I want to use Brave as a browser on my Imac ( Mojave & BigSur) I install Brave and when I try to launch the application. The Brave icon is displayed on the bottom bar of my mac, it jumps twice and goes away as if it crashes and nothing is displayed. Do you have a solution so that I can use Brave
Thanks a lot
Have a nice evening
Hello @theoparmentier
try to open brave from terminal by using this command
open -a "Brave Browser.app" -n --args --disable-gpu
if it work then go to brave://settings/system and turn off hardware acceleration then close brave and open it in the normal way
