Hi Team,
Just want to report that my browsers just automatically contributed like 5 USD to a certain website without my knowledge. I’ve been using Brave for a few months now and this is the first time that I’ve encountered this issue.
Hope someone can help me with regards to this matter.
Many thanks,
Gelo
But you had the auto contribute off? Or you forgot to disable that feature?
I think I forgot to disable that feature. But its kinda weird since I’ve been using if for like few months now and this is the first time that it contributed to a certain website.
Have you check if that site is from a registered brave creator?
Most of sites now are not. If that’s the case, your BAT will be re-credited to you in a term of 3 months (if that website don’t becomes a brave creator in that lapse of time).
Its wikipedia and alternativeto.net/
