heating issue in macbook pro m1 , while using brave
@garv,
Can you try disabling Hardware Acceleration in settings to see if this resolves the issue?
You’ll find this in Settings --> Additional Settings --> System --> Hardware Acceleration
I already tried disabling and also cleared history/cache etc but still the issue persists
If you were to create a temp. new profile and use the new profile for a bit (ensuring that your original profile window is closed, such that only the newly created profile is running, do you still see the same overheating?
