hCaptcha is not showing with adblocker
HI support,
I am using latest version of brave but once I enable shields for any site. hCaptcha is not showing but if I disable shields it’s start working, I want to keep brave adblocker to visit the sites.
screenshot with shields: https://tinyurl.com/y3hyp4sc
screenshot without shields: https://tinyurl.com/y322nrr6
Is there any solution for this issue?
Thanks,
Love Brave
Sample page? Just testing the sample hcaptcha test on https://www.hcaptcha.com/ No fails so far. @Ahtisham1122
Thanks for your reply. Kindly test it on this site https://png.is/tool/findstock?code=e079aff6e04e4fff899daa3c651ee95e
Couldn’t bring up the captcha with or without a VPN. Does the sample hcaptcha on their main page fails?
Sample hCaptcha is working fine but for this site it’s not working if I enable brave shields and I really need this site without ads. LOL!
Does this site work in private window mode, if you clear the cookies and cache via brave://settings/clearBrowserData ? We don’t target hcaptcha when blocking ads/trackers here
I did everything like clearing caches and trying in private window but it’s only work when I disable brave shields
Which specific shield option?
Standard
Screenshot_2
I mean, which shield option fixes the issue. So adjusting each shield option helps?
If I enable3rd option “Allow all trackers & ads” then it’s start working
do you have any subscriptions enabled in brave://adblock ?
Also, what urls are showing as blocked in the Ads and Trackers drop down?
Not sure about this …
Hi @fanboynz
Any update for me?
or is there a way I can close this popup?
Those ads are blocked by Brave already @Ahtisham1122 I would test in a clean Brave Beta profile also given the issues you have been having.
