Asyou can see it cuts off the right hand side of the chrt. i cant see the numbers which are normally displayed.
I have no clue. Any ideas pls?
Hello,
Thanks for reaching out. Could you tell me the name of the website so I can look into it more?
@Paisleyred,
This issue has been addressed here before. Make sure you use the search function before submitting a topic as per the posting guidelines.
See the solution here and let me know if this resolves your issue:
Hi, thanks. Its 3 commas website. It has a button that allows you to look at charts via trading view. Works fine on other browsers.
Hope that helps
With kindness
Rob
thankyou i did look around for previous. all fixed now. have a great day
