I haven’t see ads in weeks now, my version is Version 1.16.76 Chromium: 86.0.4240.198 (Official Build) (64-bit)
Any Help or Reason is appreciated… Thanks.
Dude Force stop your Browser from Application manager if you’re using Android.Then you need to off brave rewards for an hour.After an hour go back to brave and on & browse.Wish it will work. Also check you installed latest version & there are ads campaign in your Country.
Thank you
Thanks a lot, but its for windows…
You can off on brave rewards
