Briefly describe your issue: Have not received October payout and have not seen any new ads in over a week.
Version 1.32.106 Chromium: 96.0.4664.45 (Official Build) (64-bit)
Is your browser wallet currently verified? (yes/no) yes
What date did you verify your wallet? September 1, 2021
Have you been able to successfully receive payments in the past? yes
Are you in a supported region (see here for list of supported regions)? yes
Does your device pass the SafteyNet check (Android only)? not on android
Have you manually turned off Auto-contribute on all of your devices linked to Uphold?? don’t use uphold
