Hark disk 100% usage problem
Hi, I need help with this problem, I have made a search in the community but the solution I have found is that I have to deactivate the rewards…
The problem is when I’m using brave my hard disk usage is always at 100% and I have discovered that only occurred when the rewards option is active, why is this happen.
I don’t want to have to deactivate the rewards, this is the main reason why I’m using this browser.
I have the browser up to date.
Could you help with this problem, please?
@cachimery,
Can you tell me if you’re using Windows 10 or Windows 7? In addition, do you have any extensions installed in the browser at this time?
I’m using windows 10 and I’m no using any extension.
Can you try disabling Hardware Acceleration in settings to see if this resolves the issue?
You’ll find this in Settings --> Additional Settings --> System --> Hardware Acceleration
I already did that, didn’t work.
