Hello,
I have many tabs opened with many groups for my work and it looks messy. It would be awesome if there a feature for hiding the tabs and then when needed click on the group name and it will expend and shows the tabs.
Thanks and regard
Jack
Hello,
Thanks and regard
Jack
Feature is already there. Works as in Chrome: tab groups.
Hold down and click on the tabs you want to group or just right click on a single tab.
If you right-click on any of those tabs, you’ll see an option to “add tab to group”. You can create a new group of tabs or add the tab to an existing group.
If you don’t name the tab, it’ll create a colored dot on the tab bar. If you add a name, that will be visible. If you click on it, it will expand and your tabs will be visible.
Once a tab group is created, you can easily drag new tabs in our out of the group.
That does not appear to hide the individual tabs.
After creating and populating a tab group, both the group and the entire set of tabs still appear in the tab bar.
Just click on the group name to collapse/expand the group.
hi…is there a way for me to see the groups from my laptop brave browser, on a mobile brave browser…it seems as i can view all the tabs from my desktop, but not the groups…that would be soooooo nice
and effective…
will this feature save tabs after closing brave and reopening? I cannot find it if available?
I think what the OP is really asking is for the group names to be hidden. Like having them in a drop down menu much like his Simple Tab Groups works for Firefox or how Zen browser works by default.
