Google Drive repeatedly disconnects and won't load on macos
I recently switched from a PC to a Mac and ported over my profiles. I’m connected to the internet with good signal according to eero, but Google Drive fails to load links or stay connected long enough for me to edit documents, slides, spreadsheets, etc. When I open the file in Chrome, it works perfectly at the same time it does not in Brave.
  1. Access Brave on MacOS
  2. Open Google Drives file, such as “sheet” or “slides”
  3. Attempt to work in it for more than 10 mins.
  4. Repeatedly lose your work as the document says “offline”
Expected result: uninterrupted working time.
About Brave v 1.78.97
Google Drive/other Google apps seem to be working fine on my end. Do you have any extensions installed in the browser at this time?
