Website using geolocation to get local weather does not work on brave desktop, possibly android browser as well.
- Go to https://redskyready.com/wx/
- Allow geolocation if it triggers
- If the geolocation works additional data will flow in including hourly weather, weekly forecast etc. The website works fine in Edge and Chrome.
- Gelocation does not trigger or does not get the data.
- Inspect element Error in fetchandstorelocation
wx/:324 Error in fetchAndStoreLocation:
GeolocationPositionError
code: 2
message: “”
[[Prototype]]: GeolocationPositionError
1. PERMISSION_DENIED: 1
2. POSITION_UNAVAILABLE: 2
3. TIMEOUT: 3
4. code: (...)
5. message: (...)
7. constructor: ƒ GeolocationPositionError()
8. Symbol(Symbol.toStringTag): "GeolocationPositionError"
9. get code: ƒ code()
10. get message: ƒ message()
11. [[Prototype]]: Object
fetchAndStoreLocation @ wx/:324
Every time Desktop
Often on Android.
Windows 10
Version 1.74.48
Android 14
There is likely a better way to write my code to fix this but it works on all the other browsers so if you could fix it that would be awesome!
