Description of the issue: General Adblock settings get ignored
Go to settings and disable adblock
Open any website
Expected result: Newly opened website should have the Brave shields activated but adblocking should remain disabled.
Actual result: Adblock is active when you tap on the shields icon.
Brave Version( check About Brave): 1.5.131 German locale
Mobile Device details: Different devices running Android 5 and 9
Additional Information: See attached screenshots. I’m pretty sure I have seen this bug before. Currently there is no way to show ads by default on any websites because settings will get ignored.
Stup*id me, thanks @MaximeJ, you were exactly right. Enabling and disabling the settings again solved the issue. No idea why I haven’t thought of this before.
