Gemini wallet will not verify. Keep getting “Sorry there was a problem processing your request, please try again.” message. I have tried to verify for a few days now.
Hi and welcome to the community. ![]()
There isn’t enough information for either a community member or a moderator to help. Can you please provide the following information.
Brave version and OS (first three lines at brave://version)
Are you in a supported region?
For Gemini, you can check here and for Brave, you can check here. Please note that in the Brave list only creator accounts are supported if you are from the Philippines. -
Is your Gemini account verified? You can check in your account profile. It will display “verified” if you are.
Is your
Wallet status: VerifiedandCustodian: Geminidisplayed at brave://rewards-internals underExternal wallet info? (do not post your wallet id! keep it private)
Version 1.36.119 Chromium: 99.0.4844.83 (Official Build) (64-bit)
Yes supported with Gemini and Brave
3.Yes my account is verified
- No my wallet is not verified that is what Im having problems with,
Just wanted to check that it was empty. ![]()
You should DM the moderators with your wallet payment id found at brave://rewards-internals. Do not post this information.
Mattches and Steeven are the moderators who handle most of the rewards issues.
How to DM a moderator:
- Click on their icon and select the Message button in the top right corner or
- You can go to your profile and create a new message in Messages.
Alright thank you Chocoholic!!!
