Hey. My BAT rewards not working from beginning off 2026 year. When this bug will be fixed?
@LovLaus I moved to your own topic as you should have made one instead of hijacking an unrelated one. That said, you can’t really be helped because you chose not to explain why you say is “not working” or why you think there’s a bug.
If it’s just that you have not been receiving payments, then you would need to follow instructions as you would have seen in the template if you created a topic:
If you have a payment issue please submit a ticket to us directly.
Otherwise, it would ask you for:
Briefly describe your issue:
What Operating System and Brave version are you using? (
Menu --> About Brave)Who is your verified custodian? (Uphold/Gemini/bitFlyer)
But without knowing the specific version of Brave you’re using, exactly which OS you’re on, which region you’re in, and all the specifics of what you see as an issue…how do you think anyone can try to help?
