Briefly describe your issue:
I just started to use/verify brave rewards two months ago, by Christmas I would like to report to issues related with Brave Rewards.
Firstly, February rewards not accrued to my Gemini, the amount shown in my Gemini accounts remains unchanged, albeit the information of February rewards is not visible anymore.
Secondly, I noticed that BAT earnings counting has frozen and remains unchanged for a week or so.
Thanks in advance for your support and assistance.
What Operating System and Brave version are you using ( Menu --> About Brave )?
OS: Windows 10 (64-bit)
Brave: Version 1.36.112 Chromium: 99.0.4844.51 (Official Build) (64-bit)
Yes.
Yes.
Until January no issues.
Are you using a VPN? (yes/no)
No.
Are you in a supported region (see here 8 for list of supported regions)?
I think I am. I am based in Portugal, Europe.
Does your device pass the SafteyNet 4 check (Android only)?
At the moment, not using Brave in android yet.
I opted to link to Gemini
