Failed patches when running 'npm run init'
So I was following the Wikis on how to build the browser on my local machine. When running ‘npm run init’ I got 62 failed patches. I’ll include some screenshots.
Hi @garret123h
Thanks for reaching out - super glad to see you get setup :slight_smile:
This is a fairly common thing that happens after we upgrade Chromium. Try giving these steps a try:
  • under src/brave checkout master, pull latest
  • at the root (.), pull latest
  • run npm run init to restart the process
At this point, it should grab the latest Chromium version we have, the latest brave-core, and then when the hooks are ran by gclient it’ll execute the patches. Let me know if that fixes you up :smile:
Hi Clifton, thanks for the response! I implemented your suggestions and it worked perfectly. Thank you
You’re very welcome! Let me know here or via GitHub (bsclifton) if you need help with a specific area of the code or you’re looking for an issue to fix :slight_smile:
