New User - Succcessfully downloaded 1Password Extension
Shows in list if I click on Extensions icon - but its icon not visible on its own in Task Bar
Not in Dark Mode
Appreciate any help!
Hello @DocJMB
go to brave://extensions/ and check if it’s setting there
Yep, it’s in there but the icon is not displayed on the taskbar - nice to just click on the icon when needed rather than the 2 steps of hitting the Extension icon & then the one I want.
1st world problem!
Oops…Problem Solved!
Click on Extensions Icon —> Click on Pin icon beside the extensions name in the list —> icon appears beside he Extensions icon!!
that what i meant
glad you figured it out and have a nice day
