Edge will not allow seach.brave.com to be selected as default browser in Edge
Edge in Windows 10 will not allow seach.brave.com to be selected as default browser even when added to Manage search engines. It does not appear as a choice although google etc. are all listed as choices
https://search.brave.com/
@ken3491phillips Hi and welcome to the community. :slightly_smiling_face:
Do you have Brave up at the same time as Edge? If I have both up at the same time, the settings I try to make in Edge did not work for some reason. If I close both browsers, then open just Edge, I can make the changes and then they will work, even if both browsers are open. Not sure why, it just did.
Edit: Oh, want to add, I am using Brave version 1.36.112, not Beta.
Just saw this in another post. Thought you might be interested. I did not use this string but mine worked anyway. Going to go see later if it makes a difference in anything. :slightly_smiling_face:
https://community.brave.app/t/brave-search-in-non-beta-brave-brower/357379/2?u=chocoholic
